Logitech K480 Flex Circuit Replacement
  1. Logitech K480 Flex Circuit Replacement, Back Cover: step 1, image 1 of 1
    • Flip the keyboard over.
    Ask FixBot
  2. Logitech K480 Flex Circuit Replacement: step 2, image 1 of 3 Logitech K480 Flex Circuit Replacement: step 2, image 2 of 3 Logitech K480 Flex Circuit Replacement: step 2, image 3 of 3
    • Remove the four rubber feet with a spudger.
    Ask FixBot
  3. Logitech K480 Flex Circuit Replacement: step 3, image 1 of 3 Logitech K480 Flex Circuit Replacement: step 3, image 2 of 3 Logitech K480 Flex Circuit Replacement: step 3, image 3 of 3
    • Slide open battery panel.
    • Remove the batteries.
    Ask FixBot
  4. Logitech K480 Flex Circuit Replacement: step 4, image 1 of 2 Logitech K480 Flex Circuit Replacement: step 4, image 2 of 2
    • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
    Ask FixBot
  5. Logitech K480 Flex Circuit Replacement: step 5, image 1 of 2 Logitech K480 Flex Circuit Replacement: step 5, image 2 of 2
    • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
    Ask FixBot
  6. Logitech K480 Flex Circuit Replacement: step 6, image 1 of 3 Logitech K480 Flex Circuit Replacement: step 6, image 2 of 3 Logitech K480 Flex Circuit Replacement: step 6, image 3 of 3
    • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
    • Slide a blue pick in to keep the pieces apart while you work on other areas.
    • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
    • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
    Ask FixBot
  7. Logitech K480 Flex Circuit Replacement, Metal Plate: step 7, image 1 of 3 Logitech K480 Flex Circuit Replacement, Metal Plate: step 7, image 2 of 3 Logitech K480 Flex Circuit Replacement, Metal Plate: step 7, image 3 of 3
    • Remove the eight 3 mm screws using a Phillips #00 screwdriver
    • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
    • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
    Ask FixBot
  8. Logitech K480 Flex Circuit Replacement: step 8, image 1 of 2 Logitech K480 Flex Circuit Replacement: step 8, image 2 of 2
    • Lift up and remove the metal plate.
    Ask FixBot
  9. Logitech K480 Flex Circuit Replacement, Flex Circuit: step 9, image 1 of 2 Logitech K480 Flex Circuit Replacement, Flex Circuit: step 9, image 2 of 2
    • Remove the two black 4 mm screws from the motherboard with a Phillips #00 screwdriver.
    Ask FixBot
  10. Logitech K480 Flex Circuit Replacement: step 10, image 1 of 2 Logitech K480 Flex Circuit Replacement: step 10, image 2 of 2
    • Gently pull the flex circuit from the back of the motherboard.
    • The flex circuit is fragile so be gentle when pulling it out.
    Ask FixBot
  11. Logitech K480 Flex Circuit Replacement: step 11, image 1 of 2 Logitech K480 Flex Circuit Replacement: step 11, image 2 of 2
    • Remove the two black 4 mm screws from the dial motherboard below the regular motherboard with a Phillips #00 screwdriver.
    Ask FixBot
  12. Logitech K480 Flex Circuit Replacement: step 12, image 1 of 1
    • Gently pull the circuit sheet from behind the dial motherboard.
    Ask FixBot
  13. Logitech K480 Flex Circuit Replacement: step 13, image 1 of 1
    • Remove the two black 4 mm screws holding the Bluetooth component on the left side using a Phillips #00 screwdriver.
    Ask FixBot
  14. Logitech K480 Flex Circuit Replacement: step 14, image 1 of 1
    • Lift the flex circuit and remove.
    Ask FixBot
2 other people completed this guide.
Madison
688 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 41
All Time: 464
