Logitech K480 Easy-Switch Dial Replacement
    1. Logitech K480 Easy-Switch Dial Replacement, Back Cover: step 1, image 1 of 1
      • Flip the keyboard over.
      Ask FixBot
    2. Logitech K480 Easy-Switch Dial Replacement: step 2, image 1 of 3 Logitech K480 Easy-Switch Dial Replacement: step 2, image 2 of 3 Logitech K480 Easy-Switch Dial Replacement: step 2, image 3 of 3
      • Remove the four rubber feet with a spudger.
      Ask FixBot
    3. Logitech K480 Easy-Switch Dial Replacement: step 3, image 1 of 3 Logitech K480 Easy-Switch Dial Replacement: step 3, image 2 of 3 Logitech K480 Easy-Switch Dial Replacement: step 3, image 3 of 3
      • Slide open battery panel.
      • Remove the batteries.
      Ask FixBot
    4. Logitech K480 Easy-Switch Dial Replacement: step 4, image 1 of 2 Logitech K480 Easy-Switch Dial Replacement: step 4, image 2 of 2
      • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
      Ask FixBot
    5. Logitech K480 Easy-Switch Dial Replacement: step 5, image 1 of 2 Logitech K480 Easy-Switch Dial Replacement: step 5, image 2 of 2
      • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
      Ask FixBot
    6. Logitech K480 Easy-Switch Dial Replacement: step 6, image 1 of 3 Logitech K480 Easy-Switch Dial Replacement: step 6, image 2 of 3 Logitech K480 Easy-Switch Dial Replacement: step 6, image 3 of 3
      • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
      • Slide a blue pick in to keep the pieces apart while you work on other areas.
      • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
      • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
      Ask FixBot
    1. Logitech K480 Easy-Switch Dial Replacement, Metal Plate: step 7, image 1 of 3 Logitech K480 Easy-Switch Dial Replacement, Metal Plate: step 7, image 2 of 3 Logitech K480 Easy-Switch Dial Replacement, Metal Plate: step 7, image 3 of 3
      • Remove the eight 3 mm screws using a Phillips #00 screwdriver
      • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
      • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
      Ask FixBot
    2. Logitech K480 Easy-Switch Dial Replacement: step 8, image 1 of 2 Logitech K480 Easy-Switch Dial Replacement: step 8, image 2 of 2
      • Lift up and remove the metal plate.
      Ask FixBot
    1. Logitech K480 Easy-Switch Dial Replacement, Easy-Switch Dial: step 9, image 1 of 1
      • Remove the two black 4 mm screws from the dial motherboard located on the upper right corner of the device with the Phillips #00 screwdriver.
      Ask FixBot
    2. Logitech K480 Easy-Switch Dial Replacement: step 10, image 1 of 2 Logitech K480 Easy-Switch Dial Replacement: step 10, image 2 of 2
      • Lift the Easy-Switch motherboard up to pop it out from the dial.
      Ask FixBot
    3. Logitech K480 Easy-Switch Dial Replacement: step 11, image 1 of 3 Logitech K480 Easy-Switch Dial Replacement: step 11, image 2 of 3 Logitech K480 Easy-Switch Dial Replacement: step 11, image 3 of 3
      • Pop out the Easy-Switch dial by gently pressing your finger on the underside of of the dial.
      Ask FixBot
Marie Sewell
354 Reputation
2 Guides authored
1 Guide Comment
Very good tutorial, it's a shame we don't know where to get the Logitech K480 Easy-Switch Dial part. Sincerely.
Herve SPADACINI - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 75
All Time: 720
