Introduction
This is a replacement guide for the keyboard printed circuit board.
The keyboard printed circuit board (PCB) sends messages to the wifi and transmits key data to the server.
Peel off the center sticker to reveal two hidden 4.0 mm screws.
Unscrew these two screws with a Phillips #1 screwdriver.
Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
Wedge the flat end of the spudger between the back panel and front panel.
Slide the flat end of the spudger from right to left to pry the two panels apart.
Grip the lower end of the ribbon flex cable (white band) using your thumb and index finger.
Then slide the strip out toward yourself in a scooping motion.
Unscrew the two 4.0 mm screws on either side of the green card using a Phillips #1 screwdriver.
Grip and lift the battery wire bar out of the battery compartment, using your thumb and index finger.
Pinch your precision tweezers and wedge the battery clamp up.
Lift the entire keyboard PCB out of the panel.
Slide your index finger into the slot under the right blue tab.
Pinch and pull the right blue tab away from the green card.
