Logitech Harmony Smart Keyboard Back Panel
  1. Logitech Harmony Smart Keyboard Back Panel, Back Panel: step 1, image 1 of 2 Logitech Harmony Smart Keyboard Back Panel, Back Panel: step 1, image 2 of 2
    • Turn keyboard over to the backside.
  2. Logitech Harmony Smart Keyboard Back Panel: step 2, image 1 of 3 Logitech Harmony Smart Keyboard Back Panel: step 2, image 2 of 3 Logitech Harmony Smart Keyboard Back Panel: step 2, image 3 of 3
    • Press and slide up on the upper battery latch, using both thumbs.
  3. Logitech Harmony Smart Keyboard Back Panel: step 3, image 1 of 1
    • Remove the two AA batteries and set them aside.
  4. Logitech Harmony Smart Keyboard Back Panel: step 4, image 1 of 2 Logitech Harmony Smart Keyboard Back Panel: step 4, image 2 of 2
    • Unscrew all five 4.0 mm screws, using Phillips #1 screwdriver.
  5. Logitech Harmony Smart Keyboard Back Panel: step 5, image 1 of 2 Logitech Harmony Smart Keyboard Back Panel: step 5, image 2 of 2
    • Peel off the center sticker to reveal two hidden 4.0 mm screws.
    • Unscrew these two screws with a Phillips #1 screwdriver.
  6. Logitech Harmony Smart Keyboard Back Panel: step 6, image 1 of 3 Logitech Harmony Smart Keyboard Back Panel: step 6, image 2 of 3 Logitech Harmony Smart Keyboard Back Panel: step 6, image 3 of 3
    • Lift both top left and top right rubber stickers halfway, using the sharp end of the plastic spudger.
    • Unscrew a total of two 4.0 mm screws, under the rubber stickers, using a Phillips #1 screwdriver.
  7. Logitech Harmony Smart Keyboard Back Panel: step 7, image 1 of 2 Logitech Harmony Smart Keyboard Back Panel: step 7, image 2 of 2
    • Unscrew the top center 4.0 mm screw, in the battery compartment, using the Phillips #1 screwdriver.
    • Now, you should have a total of ten 4.0 mm screws set aside.
  8. Logitech Harmony Smart Keyboard Back Panel: step 8, image 1 of 3 Logitech Harmony Smart Keyboard Back Panel: step 8, image 2 of 3 Logitech Harmony Smart Keyboard Back Panel: step 8, image 3 of 3
    • Wedge the flat end of the spudger between the back panel and front panel.
    • Slide the flat end of the spudger from right to left to pry the two panels apart.
  9. Logitech Harmony Smart Keyboard Back Panel: step 9, image 1 of 3 Logitech Harmony Smart Keyboard Back Panel: step 9, image 2 of 3 Logitech Harmony Smart Keyboard Back Panel: step 9, image 3 of 3
    • Separate the back panel from the front panel completely, using both hands.
    • A white ribbon flex cable will remain connected to both panels.
    • Pull the panels apart slowly and gently, or the white ribbon flex cable may be unsafely removed.
Hayley Nichols
525 Reputation
4 Guides authored
CSU Fullerton, Team S1-G2, Bruce Fall 2017 Member of CSU Fullerton, Team S1-G2, Bruce Fall 2017
CSUF-BRUCE-F17S1G2
3 Members
10 Guides authored
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 20
All Time: 1,021
