Introduction
This guide shows you how to begin the disassembly of the Logitech Harmony 650 Universal Remote. It is recommended that you have the iFixit ProTech Toolkit.
Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
The top led protector plastic cover will also be freed once back is removed.
