Logitech G910 Keyboard Key Cap Replacement
    1. Logitech G910 Keyboard Key Cap Replacement, Key: step 1, image 1 of 1
      • Unplug the keyboards USB cord from the computer. This is to ensure it is powered off.
      • Make sure the keyboard is facing up towards you and on a level and sturdy surface.
      Ask FixBot
    2. Logitech G910 Keyboard Key Cap Replacement: step 2, image 1 of 1
      • Gently use your fingers to remove the key caps from the keyboard by firmly grasping the key and pulling directly up.
      • Make sure the pins line up and it is facing the correct direction. Once you have done this, firmly push it in until you hear it click into place and works like normal again.
      • If the key cap doesn't push in all the way or won't pop back up from being pressed down then it is either in the wrong spot or oriented the wrong way. Pull it off, make sure no debris is blocking the pin hole and try putting it the correct way again.
      Ask FixBot
10 other people completed this guide.
13 Guide Comments
I am sorry, but why did you wrote a tutorial and describe how to open up G910 (and lose the warranty along the way) just to take of the keyCAP?
Keycap can be removed in a matter of seconds with use of $0.99 keycap removal tool
https://www.ebay.com/itm/Keyboard-Key-Ke...
heggathestrasni - Reply Share
It’s not just the Key Cap, you can remove the mechanical switch too. I have a busted G910 and I’ve been wanting to replace the switches for a while now.
Wildcard001 - Reply Share
dude same, I have a few broken switches on mine that I'm keeping held together with some wadded up paper. the 9 key is completely gone sadly.
Shady Hero - Reply Share
Rofl, you don’t need to do steps 1-4, literally jusst do 5 if you are replacing the keycap lmao
rob.chan - Reply Share
I think step 3 and 4 are in the wrong order, you can’t get to the screws until you get that face-plate off
Brett Yoakum - Reply Share
Past 24 Hours: 8
Past 7 Days: 75
Past 30 Days: 269
All Time: 70,973
