Logitech G700s Top Case Replacement
  1. Logitech G700s Top Case Replacement, Top Case Replacement: step 1, image 1 of 1
    • Remove the batteries from the mouse.
    • Use a plastic opening tool to peel up the four mouse feet.
  2. Logitech G700s Top Case Replacement: step 2, image 1 of 2 Logitech G700s Top Case Replacement: step 2, image 2 of 2
    • Remove the five 5.5mm Phillips #00 screws found underneath the mouse feet.
  3. Logitech G700s Top Case Replacement: step 3, image 1 of 3 Logitech G700s Top Case Replacement: step 3, image 2 of 3 Logitech G700s Top Case Replacement: step 3, image 3 of 3
    • Pull the top of the mouse off of the bottom half.
    • There's a wire connecting the two halves.
    • Unplug the programmable buttons from the motherboard.
    • The white pin housing on the motherboard may come off while unplugging. In that case, use tool to pry between at location indicated to separate them and insert the housing back onto the motherboard.
Chase Tisinger
687 Reputation
5 Guides authored
USF Tampa, Team S2-G3, Nance Spring 2018 Member of USF Tampa, Team S2-G3, Nance Spring 2018
USFT-NANCE-S18S2G3
4 Members
15 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 32
All Time: 3,039
