Introduction
This guide will shop you how to open the logitech G700s, this is necessary for cleaning, replacing the scroll wheel and replacing the left and right click switches.
Remove the batteries from the mouse.
Use a plastic opening tool to peel up the four mouse feet.
Use the PH00 screw bit to remove the five 5.5mm screws located under where the mouse feet were located in step 1.
Carefully remove the wires that connect the programmable buttons to the circuit board. It is pretty snug but using tweezers or a plastic opening tool helped loosen it.
