Introduction
By following this guide you will be able to remove and replace the quad side button array on your Logitech G700s gaming mouse.
Remove the batteries from the mouse.
Use a plastic opening tool to peel up the four mouse feet.
Pull the top of the mouse off of the bottom half.
Unplug the programmable buttons from the motherboard.
Remove the three 5.5mm Phillips #00 screws holding the button assembly to the mouse.
First, unhook the cables from the cable guide so it won't get caught while popping the assembly out
The assembly is held in by some clip-in action from the screw posts on the top shell and screw holes on the assembly
