Up to 20% off select tools
Logitech G603 Wheel Encoder Replacement
Views: 7.4K
View statistics:
Past 24 Hours:
8
Past 7 Days:
53
Past 30 Days:
296
All Time:
7,415
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Logitech G603 mouse wheel encoder replacement.
The encoder is a Logitech 210-001795. It's possible the PCB color on replacements is different than what's inside the G603.
    1. Logitech G603 Wheel Encoder Replacement, Remove Top Cover & Batteries: step 1, image 1 of 1
      • Remove magnetic top cover, batteries, and wireless receiver (if currently stored inside the mouse)
      Ask FixBot
    2. Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: step 2, image 1 of 3 Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: step 2, image 2 of 3 Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: step 2, image 3 of 3
      • Carefully remove the feet to reveal the 4 screws holding the top and bottom shells together
      • NOTE: These feet can be removed carefully enough to be reused. Only the top and bottom feet need to be removed, not the one around the sensor
      Ask FixBot
    3. Logitech G603 Wheel Encoder Replacement, Remove the four Phillips #00 Screws: step 3, image 1 of 1
      • Use Phillips #00 to remove the four bottom screws
      Ask FixBot
    4. Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: step 4, image 1 of 3 Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: step 4, image 2 of 3 Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: step 4, image 3 of 3
      • Start at the top above the left and right click and slowly work your way around the shells until they are separated
      • Be careful not to damage the power connector or ribbon cable going from the top shell's boards/battery to the bottom shell's board
      Ask FixBot
    5. Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: step 5, image 1 of 3 Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: step 5, image 2 of 3 Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: step 5, image 3 of 3
      • Start with the red and black power cable and gently pull it out
      • Once power cable is removed, you should be able to unfold the two halves and unplug the white ribbon cable
      Ask FixBot
    6. Logitech G603 Wheel Encoder Replacement, Remove Encoder Ribbon Cable: step 6, image 1 of 1
      • Gently pull out the black ribbon cable connecting the encoder board to the main board
      Ask FixBot
    7. Logitech G603 Wheel Encoder Replacement, Remove 5 Phillips #00 Screws: step 7, image 1 of 1
      • Remove the Phillips #00 screws holding the encoder board in place
      Ask FixBot
    8. Logitech G603 Wheel Encoder Replacement, Remove Encoder Board & Wheel: step 8, image 1 of 1
      • Remove the encoder board from the bottom shell
      • Gently remove the wheel from the older encoder board
      • NOTE: The old wheel can be reused in the replacement encoder board
      Ask FixBot
Author
with
Jim
331 Reputation
2 Guides authored
1 Guide Comment
In my case, cleaning the encoder plate in an ultrasonic bath did the trick.
dobromir.dombek - Reply Share
Past 24 Hours: 8
Past 7 Days: 53
Past 30 Days: 296
All Time: 7,415
