Lenovo IdeaPad U530 Touch Hard Drive Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
74
All Time:
1,224
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes - 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
This is a step-by-step guide on how to replace the hard drive inside Lenovo IdeaPad U530 Touch laptop.
Symptoms related to hard drive failure are as follows:
- blue screens,
- loud scratching or clicking noises,
-and a “file not found” error when opening a file.
Make sure to wear gloves when operating inside the device.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Lenovo IdeaPad U530 Touch Hard Drive Replacement, Battery: step 1, image 1 of 3 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Battery: step 1, image 2 of 3 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Battery: step 1, image 3 of 3
      • Remove the back panel by removing all screws. Use a PH000 screwdriver head.
      • Make sure to also remove the hinge screws.
      Ask FixBot
    2. Lenovo IdeaPad U530 Touch Hard Drive Replacement: step 2, image 1 of 2 Lenovo IdeaPad U530 Touch Hard Drive Replacement: step 2, image 2 of 2
      • To remove the panel, use a plastic opening tool to prevent any damage.
      Ask FixBot
    3. Lenovo IdeaPad U530 Touch Hard Drive Replacement: step 3, image 1 of 1
      • Locate and assess the battery. Pictured in the upper right area of the computer.
      Ask FixBot
    4. Lenovo IdeaPad U530 Touch Hard Drive Replacement: step 4, image 1 of 2 Lenovo IdeaPad U530 Touch Hard Drive Replacement: step 4, image 2 of 2
      • Locate and remove all screws attaching the battery to the hull of the computer. It is recommended that you use a JIS #1 screwdriver head for this task.
      • Be careful to keep track of all removed screws.
      Ask FixBot
    5. Lenovo IdeaPad U530 Touch Hard Drive Replacement: step 5, image 1 of 1
      • Detach the connection from the battery to the motherboard. This is the only connection that needs to be disconnected for the battery.
      • To remove the connection, please pull firmly, as it well secured.
      Ask FixBot
    6. Lenovo IdeaPad U530 Touch Hard Drive Replacement: step 6, image 1 of 1
      • Simply lift the battery out of the computer, and acquire a replacement.
      Ask FixBot
    1. Lenovo IdeaPad U530 Touch Hard Drive Replacement, Hard Drive: step 7, image 1 of 3 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Hard Drive: step 7, image 2 of 3 Lenovo IdeaPad U530 Touch Hard Drive Replacement, Hard Drive: step 7, image 3 of 3
      • Remove two 3 mm screws connecting the hard drive to the computer base using a JIS #1 screwdriver.
      • Detach the connection from the hard drive to the motherboard.
      • Remove the hard drive from the laptop.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 74
All Time: 1,224
