Nvidia Shield Pro Android TV Controller Triggers Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
61
All Time:
865
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Every gamer knows how important triggers are for our gaming experience. So, if your Nvidia Shield Pro Android TV Controller triggers are sticking or aren't functioning properly, then you need to replace your controllers’ triggers. Luckily, you're in the right place, this is an easy to follow guide and there are no special skills required. The goal of this guide is for you to be able to properly replace the controllers’ triggers, so you can go back to enjoying your games. Although, please be cautious when disconnecting the wires and gently apply pressure to thumbsticks when removing so nothing gets damaged. Lastly, Two different screwdrivers will be used, so if you're unfamiliar with them, then please refer to this link for Screwdriver Best Practices.
Tools
    1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: step 1, image 1 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: step 1, image 2 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Thumbsticks: step 1, image 3 of 3
      • Remove the six T6 Torx screws from the back of the controller.
      Ask FixBot
    2. Nvidia Shield Pro Android TV Controller Triggers Replacement: step 2, image 1 of 1
      • Gently pry open the top frame of the cover with a plastic opening tool.
      Ask FixBot
    3. Nvidia Shield Pro Android TV Controller Triggers Replacement: step 3, image 1 of 2 Nvidia Shield Pro Android TV Controller Triggers Replacement: step 3, image 2 of 2
      • Gently pull the wire connector directly out of its socket, separating the two halves of the controller.
      Ask FixBot
    4. Nvidia Shield Pro Android TV Controller Triggers Replacement: step 4, image 1 of 2 Nvidia Shield Pro Android TV Controller Triggers Replacement: step 4, image 2 of 2
      • Remove the two T6 Torx screws.
      Ask FixBot
    5. Nvidia Shield Pro Android TV Controller Triggers Replacement: step 5, image 1 of 2 Nvidia Shield Pro Android TV Controller Triggers Replacement: step 5, image 2 of 2
      • Remove the guard piece that secures the thumb-sticks to the controller.
      • Apply vertical pressure with two fingers to carefully pop off the thumb-stick(s) in need of repair.
      • Replace it by sliding a new thumb-stick onto the plastic post that secured the old one.
      Ask FixBot
    1. Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: step 6, image 1 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: step 6, image 2 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement, Triggers: step 6, image 3 of 3
      • Use a Torx T6 screwdriver to remove the two 7 mm screws from the triggers (one on each trigger).
      • Use a Torx T5 screwdriver to remove the two 5 mm screws securing the motherboard.
      • Gently lift the motherboard from the controller housing.
      Ask FixBot
    2. Nvidia Shield Pro Android TV Controller Triggers Replacement: step 7, image 1 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement: step 7, image 2 of 3 Nvidia Shield Pro Android TV Controller Triggers Replacement: step 7, image 3 of 3
      • Use a Torx T5 screwdriver to remove the two 5 mm screws from the motherboard.
      • Carefully pull the trigger directly out of its socket.
      Ask FixBot
2 Guide Comments
how do you put the shoulder buttons back in. They fell out when I was trying to replace the battery
demarko9999 - Reply Share
Where do you buy parts? My RB broke and I'm trying to find where to buy a replacement part, but can't find anywhere.
Christian Borg Xuereb - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 61
All Time: 865
