MSI GP62MVR 6RF Leopard Pro Heatsink Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
92
All Time:
1,248
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If your laptop is running too hot or isn’t properly cooling down, the heatsink may need to be replaced. Follow the instructions in this guide to remove and replace the heatsink in your MSI GP62MVR 6RF Leopard Pro laptop.
Tools
    1. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Bottom Cover: step 1, image 1 of 2 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Bottom Cover: step 1, image 2 of 2
      • Place the laptop upside down.
      • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: step 2, image 1 of 2 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: step 2, image 2 of 2
      • Use the Jimmy tool to evenly pry loose the bottom cover.
      • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
      Ask FixBot
    3. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: step 3, image 1 of 1
      • Remove the back cover.
      • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
      Ask FixBot
    1. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Battery: step 4, image 1 of 3 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Battery: step 4, image 2 of 3 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Battery: step 4, image 3 of 3
      • Using a Phillips #0 Screwdriver, remove the single 5.5 mm screw fastening the battery to the body of the computer.
      • Remove the battery from the device.
      Ask FixBot
    1. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Speakers: step 5, image 1 of 1
      • Reorient the computer, if necessary, with a 180 degree turn so that the speakers face you.
      Ask FixBot
    2. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: step 6, image 1 of 1
      • On the front panel near the right speaker, there is a connection from the motherboard to the speakers.
      • Detach the white and black wiring from the clip.
      Ask FixBot
    3. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: step 7, image 1 of 1
      • Peel back the electrical tape holding the speaker wire in place.
      • Remove the speakers from the front panel, pulling upward.
      • Note that the screws holding the two speakers down were already removed during the bottom cover removal.
      Ask FixBot
    1. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Heatsink: step 8, image 1 of 3 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Heatsink: step 8, image 2 of 3 MSI GP62MVR 6RF Leopard Pro Heatsink Replacement, Heatsink: step 8, image 3 of 3
      • Using a Phillips #0 screwdriver, remove twelve 4.5 mm screws fastening the heat sink to the motherboard.
      • Unclip the red, blue, and black intertwined wire gently from the left side of the motherboard.
      • Detach the black and red wire from the right side of the motherboard, as well as peel away the black tape connecting the large black wire to the motherboard.
      Ask FixBot
    2. MSI GP62MVR 6RF Leopard Pro Heatsink Replacement: step 9, image 1 of 1
      • Remove the heatsink from the device.
      Ask FixBot
Justin Ogihara
31,638 Reputation
52 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 92
All Time: 1,248
