Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
7
Past 30 Days:
23
All Time:
175
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Disconnect the spark plug wire: step 1, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Disconnect the spark plug wire: step 1, image 2 of 2
      • Before you begin, ensure that the engine is powered down and cool to the touch.
      • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
      Ask FixBot
    2. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Flip the engine switch to the off position: step 2, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Flip the engine switch to the off position: step 2, image 2 of 2
      • Flip the red engine ON/OFF switch to the OFF position.
      Ask FixBot
    3. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Close the fuel valve: step 3, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Close the fuel valve: step 3, image 2 of 2
      • Flip the fuel valve lever to the OFF position.
      Ask FixBot
    4. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Turn off the ignition: step 4, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Turn off the ignition: step 4, image 2 of 2
      • Flip the ignition switch to the OFF position.
      • Ensure the wheel drive control lever is set to the neutral position.
      Ask FixBot
    5. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Allow the wheels to freewheel: step 5, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Allow the wheels to freewheel: step 5, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Allow the wheels to freewheel: step 5, image 3 of 3
      • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
      • Repeat for the left wheel.
      Ask FixBot
    6. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Add wheel chocks: step 6, image 1 of 1
      • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
      Ask FixBot
    1. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the grease fitting: step 7, image 1 of 1
      • Use an 8 mm socket to remove the outboard bearing grease fitting.
      Ask FixBot
    2. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the side plate bolts: step 8, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the side plate bolts: step 8, image 2 of 2
      • Use a 9/16 inch socket to remove the four bolts securing the tine shaft to the side plate.
      • Use a 9/16 socket and wrench to remove the five bolts and accompanying nuts securing the side plate to the frame, three on the outside and two in the wheel well.
      Ask FixBot
    3. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Tilt the tiller: step 9, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Tilt the tiller: step 9, image 2 of 2
      • Tilt the tiller up so the motor side is resting on the work surface with the tines raised.
      Ask FixBot
    4. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine cover bolts: step 10, image 1 of 1
      • Use a 1/2 inch socket and wrench to remove the four bolts and accompanying nuts securing the side plate to the tine cover.
      Ask FixBot
    5. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the side plate: step 11, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the side plate: step 11, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the side plate: step 11, image 3 of 3
      • Slide the side plate down and away from the device to remove it.
      Ask FixBot
    1. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine bolts: step 12, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine bolts: step 12, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine bolts: step 12, image 3 of 3
      • The tines closest to the tine drive motor need to be removed in order to allow access to the bolts securing the tine shaft to the hub.
      • Use a 5/8 inch socket with an 11/16 inch wrench to loosen the two 5/8 inch bolts and two 11/16 inch nuts securing the tine to the tine shaft.
      • Remove the two tine nuts.
      Ask FixBot
    2. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement: step 13, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement: step 13, image 2 of 2
      • Remove the two bolts holding the tine to the tine shaft.
      Ask FixBot
    3. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tines: step 14, image 1 of 2 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tines: step 14, image 2 of 2
      • Remove the tine.
      • Repeat this procedure for all four tines closest to the tine drive motor, opposite the outboard bearing assembly.
      • Keep track of each tine's orientation.
      Ask FixBot
    4. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine shaft bolts: step 15, image 1 of 1
      • Use a 5/8 inch socket with an 11/16 inch wrench to remove the two 5/8 inch bolts and two 11/16 inch nuts behind each removed tine.
      • Repeat this for each of the four tine locations; there are a total of eight bolts to remove.
      Ask FixBot
    5. Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine shaft: step 16, image 1 of 3 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine shaft: step 16, image 2 of 3 Barreto Tillers E1320HTRLR 2016 Tine Shaft Replacement, Remove the tine shaft: step 16, image 3 of 3
      • Remove the tine shaft from the hub.
      Ask FixBot
Carsten Frauenheim
173,247 Reputation
442 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,907 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 23
All Time: 175
