Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement
  1. Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement, Label Plate: step 1, image 1 of 2 Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement, Label Plate: step 1, image 2 of 2
    • Remove the eight 8.6 mm long 1.5 mm hex screws from the label plate.
  2. Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement: step 2, image 1 of 1
    • Use an opening tool to pry off the mode switch knob.
  3. Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement: step 3, image 1 of 3 Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement: step 3, image 2 of 3 Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement: step 3, image 3 of 3
    • Remove the eight 12.5 mm long Phillips #1 screws from the underside of the label plate.
    • These screws are plastic! Be very careful when applying force.
  4. Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement: step 4, image 1 of 2 Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement: step 4, image 2 of 2
    • Place the throttle right side up again, using the bottom panel as a coaster.
    • Gently pry the label plate from the body of the throttle.
  5. Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement, Mode Switch Potentiometer: step 5, image 1 of 2 Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement, Mode Switch Potentiometer: step 5, image 2 of 2
    • Use an 11 mm deep socket to remove the nut from the post of the switch.
  6. Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement: step 6, image 1 of 2 Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement: step 6, image 2 of 2
    • Flip the throttle over.
    • The mode switch potentiometer is identifiable by the orange plastic contact board.
    • Disconnect the potentiometer connector from the PCB by pulling it straight up and out of its socket.
  7. Logitech G X56 HOTAS Throttle Mode Switch Potentiometer Replacement: step 7, image 1 of 1
    • Gently remove the mode switch potentiometer by pulling it straight out of the base plate.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 38
All Time: 187
