Logitech G X56 HOTAS Joystick Trigger Spring Replacement
    1. Logitech G X56 HOTAS Joystick Trigger Spring Replacement, Logitech G X56 HOTAS Joystick Disassembly: step 1, image 1 of 2 Logitech G X56 HOTAS Joystick Trigger Spring Replacement, Logitech G X56 HOTAS Joystick Disassembly: step 1, image 2 of 2
      • Turn the locking bezel counterclockwise, then remove the joystick from the joystick base.
      Ask FixBot
    2. Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 2, image 1 of 3 Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 2, image 2 of 3 Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 2, image 3 of 3
      • Remove the five 11.7 mm-long Phillips #0 screws that secure the case.
      Ask FixBot
    3. Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 3, image 1 of 2 Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 3, image 2 of 2
      • Pull the joystick casing apart to reveal the internal components.
      • The casing will need a little force to split open.
      • Take care not to damage or strain the connected cable.
      Ask FixBot
    4. Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 4, image 1 of 2 Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 4, image 2 of 2
      • Grip and pull the white connector directly out of its socket.
      • The connector is fragile. If removed forcefully, it may affect the PCB performance.
      Ask FixBot
    5. Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 5, image 1 of 2 Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 5, image 2 of 2
      • Refer to the left or right side for replacement guides of other parts (left, then right side in order).
      Ask FixBot
    1. Logitech G X56 HOTAS Joystick Trigger Spring Replacement, Trigger Spring: step 6, image 1 of 2 Logitech G X56 HOTAS Joystick Trigger Spring Replacement, Trigger Spring: step 6, image 2 of 2
      • Locate the trigger button on the left dissembled side of the joystick.
      Ask FixBot
    2. Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 7, image 1 of 2 Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 7, image 2 of 2
      • Use two fingers to grab the trigger and pull upwards slowly.
      • The spring attached to the trigger pops out if not done carefully.
      Ask FixBot
    3. Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 8, image 1 of 2 Logitech G X56 HOTAS Joystick Trigger Spring Replacement: step 8, image 2 of 2
      • Detach the spring and replace it with a new one.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 53
All Time: 418
