Logitech Extreme 3D Pro Top button circuit board Replacement
  1. Logitech Extreme 3D Pro Top button circuit board Replacement, Disassembly of the handle: step 1, image 1 of 1
    • Remove these three Phillips #1 screws:
    • Two 10mm screws.
    • One 7mm screw.
  2. Logitech Extreme 3D Pro Top button circuit board Replacement: step 2, image 1 of 1
    • Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
    • Remove the two 10mm Phillips #1 screws.
  3. Logitech Extreme 3D Pro Top button circuit board Replacement: step 3, image 1 of 2 Logitech Extreme 3D Pro Top button circuit board Replacement: step 3, image 2 of 2
    • Pull apart the joystick chassis by hand.
    • Release this clip located underneath the hand rest
    • The circuit board will be loose and may fall down.
  4. Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: step 4, image 1 of 3 Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: step 4, image 2 of 3 Logitech Extreme 3D Pro Top button circuit board Replacement, Top button circuit board: step 4, image 3 of 3
    • Remove the three 7mm Phillips #1 screws from the button board.
    • Remove the button board from the plastic top.
    • When taken apart the plastic buttons can fall out.
  5. Logitech Extreme 3D Pro Top button circuit board Replacement: step 5, image 1 of 2 Logitech Extreme 3D Pro Top button circuit board Replacement: step 5, image 2 of 2
    • Disconnect the cable from the button board.
  6. Logitech Extreme 3D Pro Top button circuit board Replacement: step 6, image 1 of 2 Logitech Extreme 3D Pro Top button circuit board Replacement: step 6, image 2 of 2
    • Disconnect the smaller cable from the button board.
4 other people completed this guide.
Emanuel Canela
1,369 Reputation
7 Guides authored
USF Tampa, Team S7-G1, Passmore Spring 2018 Member of USF Tampa, Team S7-G1, Passmore Spring 2018
USFT-PASSMORE-S18S7G1
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 2,641
