Introduction
After extended use certain parts may require cleaning or replacement. This guide will assist you in safely disassembling the base portion of the joystick. This will require to have to handle already disassembled.
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
Remove the two 10mm Phillips #1 screws.
Remove these eight 10 mm long screws with a #1 Philips head screwdriver.
Flip the joystick upright.
Lift up the sliver base cover and feed the loose circuit board through.
