Introduction
If one of the six buttons on the base of joystick no longer works, it may be necessary to replace the circuit board.
Remove these three Phillips #1 screws:
Two 10mm screws.
One 7mm screw.
Using your fingers, lower the rubber boot to reveal two screws underneath the joystick.
Remove the two 10mm Phillips #1 screws.
Flip the joystick upright.
Lift up the sliver base cover and feed the loose circuit board through.
