Shop the Holiday Gift Guide
Logitech MX Ergo Disassembly
Views: 22K
View statistics:
Past 24 Hours:
12
Past 7 Days:
120
Past 30 Days:
593
All Time:
22,124
Comments: 33
11 comments on steps, 22 guide comments.
Go to guide comments
Completed: 16
16 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
So I soaked my mx ergo. this is how I disassembled and cleaned it.
Tools
    1. Logitech MX Ergo Disassembly, Logitech MX Ergo: step 1, image 1 of 1
      • Remove six T6 screws from the bottom
      Ask FixBot
    2. Logitech MX Ergo Disassembly: step 2, image 1 of 1
      • Slide a prying tool under the rightmost button and follow the seam back till the top half unclips
      Ask FixBot
    3. Logitech MX Ergo Disassembly: step 3, image 1 of 1
      • Carefully lift the top shell.
      • Do not remove the flap from the connector.
      • Release the flex ribbon from its socket.
      Ask FixBot
    4. Logitech MX Ergo Disassembly: step 4, image 1 of 1
      • Lever the scrollwheel sub-assembly free
      Ask FixBot
    5. Logitech MX Ergo Disassembly: step 5, image 1 of 1
      • Unplug the battery from the mainboard, carefully lifting the plug marked red.
      • Unscrew the three screws holding the battery submodule.
      Ask FixBot
    6. Logitech MX Ergo Disassembly: step 6, image 1 of 2 Logitech MX Ergo Disassembly: step 6, image 2 of 2
      • Unscrew the bottom left screw holding down the fwd/rev buttons, lifting the assembly to the side
      • Unplug the flex ribbon indicated in blue, coming from the power board below. Remove the six screws holding the main motherboard (one indicated orange here, just out of shot).
      Ask FixBot
    7. Logitech MX Ergo Disassembly: step 7, image 1 of 1
      • Unscrew the three screws holding the power board i place. Take care not to loose the power switch below as you take the last bits apart.
      • These three screws are a bit shorter than the rest, so keep them separate
      Ask FixBot
    8. Logitech MX Ergo Disassembly: step 8, image 1 of 2 Logitech MX Ergo Disassembly: step 8, image 2 of 2
      • There you go, all disassembled. Now remove spilled coffee.
      Ask FixBot
    9. Logitech MX Ergo Disassembly, Disassembly of top half: step 9, image 1 of 3 Logitech MX Ergo Disassembly, Disassembly of top half: step 9, image 2 of 3 Logitech MX Ergo Disassembly, Disassembly of top half: step 9, image 3 of 3
      • The right click lever comes out after the bracket covering the ribbon cable
      • The Right click lever comes out through the front/top of the mouse
      • Then the circuit boards can be removed
      Ask FixBot
    10. Logitech MX Ergo Disassembly: step 10, image 1 of 3 Logitech MX Ergo Disassembly: step 10, image 2 of 3 Logitech MX Ergo Disassembly: step 10, image 3 of 3
      • Under the circuit boards there is three piece that need to come out next
      • The first has one screw and two clear pieces that transmit the light from the circuit board to the outside of the mouse and hole to allow another to pass through it
      • Then the computer selector switch lever can come out the front/top of the mouse
      • After that the connecting light indicator transmitter will fall out and the left click lever can be removed
      Ask FixBot
16 other people completed this guide.
Author
with
Jørn-Stian
506 Reputation
1 Guide authored
22 Guide Comments
Thank you for the guide. The opening was hilarious— a picture says 1000 words.
I wanted to add a note that you need to use a T6 with a very long neck like the one iFixit offers for sale; an ordinary bit with a ~ 1/2” or ~1 cm long head will not be able to reach the two next to the opening to the thumb ball.
Allison Adz - Reply Share
I had the same issue as you. My left click got damaged somehow and wouldn’t “return” when I clicked it. Opened it up, took both springs out and compared them. Looks like the left click spring got bent somehow. Straightened it up a bit and put it back in, seems to work perfectly now! I was going to buy a new one, but now I don’t have to. Thanks for the guide and +1 for iFixIt!!!
B T - Reply Share
Hi,
My ergo fell down and I am unable to change the bluetooth selector : it is stuck on « 2 » and my pc does not see he mouse anymore.
Any idea how I could fix this ?
Thanks
Raymond Ghysels - Reply Share
tinker with the board in step 9. the button for bluetooth selection is on that board.
Frank - Reply Share
Any updates on this? Having the same issue, but stuck on 1, and won't enter pairing mode either. Removed and cleaned with IPA, hoping that works. Any idea where the actual bluetooth module is located on the board(s)? Nothing appears loose but don't get a connection with a new receiver, via cable, or bluetooth to anything that should be able to see the device. Thanks in advance.
Ricky VanWert - Reply Share
Past 24 Hours: 12
Past 7 Days: 120
Past 30 Days: 593
All Time: 22,124
