To get into the controller, you will need to unscrew the 7 screws on the back.
With the screws removed, turn the controller upside down and separate the front end from the back end.
It is likely that the buttons will fall out of place, so as you open the controller, try to keep track of where the pieces go.
There should be the 4 circular buttons labeled 1-4, 4 smaller circular buttons for the D-Pad, and 3 rounded rectangular buttons.
With the case off, the joysticks can be removed by pulling them upward.
To put the replacement joystick on, align the hole at the bottom of the joystick with the rectangular peg and gently push down.
Make sure that the cut-out side of the joystick is towards the outsides of the device.
