Up to 20% off select tools
Logitech Cube Mouse Battery Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
79
All Time:
1,719
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Parts
Tools
    1. Logitech Cube Mouse  Battery Replacement, Battery: step 1, image 1 of 1
      • Logitech Cube Mouse Battery Replacement/Removal
      Ask FixBot
    2. Logitech Cube Mouse  Battery Replacement: step 2, image 1 of 1
      • Peel the touchpad up from the support plate to make a 1 CM space.
      Ask FixBot
    3. Logitech Cube Mouse  Battery Replacement: step 3, image 1 of 1
      • Use a small thin object to pry outwards between the black plastic and white plastic to release two clips under the support plate.
      Ask FixBot
    4. Logitech Cube Mouse  Battery Replacement: step 4, image 1 of 1
      • After slowly releasing the two clips hinge up the touch panel 1 inch.
      Ask FixBot
    5. Logitech Cube Mouse  Battery Replacement: step 5, image 1 of 1
      • Slide the touch panel towards the back of the mouse 1CM.
      Ask FixBot
    6. Logitech Cube Mouse  Battery Replacement: step 6, image 1 of 1
      • Lift the touch panel and support plate.
      Ask FixBot
    7. Logitech Cube Mouse  Battery Replacement: step 7, image 1 of 1
      • Lift and rotate touch panel and support plate. Disconnect the touch panel connector, the other cable helps to sense touch.
      Ask FixBot
    8. Logitech Cube Mouse  Battery Replacement: step 8, image 1 of 1
      • Remove battery, battery plug from board connection, metal plate, and two screws. A notch in the plate matches a groove on the inside, removal at a angle is required.
      Ask FixBot
    9. Logitech Cube Mouse  Battery Replacement: step 9, image 1 of 1
      • Find another battery. Original is 533-000071 3.7v 240mAh 0.63IN x 1.18IN x 0.21IN or 16.002MM X 29.972MM X 5.334MM. There is some room for different lengths and widths, but height looks to be about 5.334MM. Due to my battery's width I had to bend a tab flat on the plate and only use 1 screw.
      Ask FixBot
    10. Logitech Cube Mouse  Battery Replacement: step 10, image 1 of 1
      • Press the touch pad and support plate together to undo slightly peeling them apart. Attach the battery to the plate, Install plate/ battery in mouse. Plug in battery and touch panel cables, rotate touch panel and support plate back into place. Place the front tab in its slot and press the back down to attach the clips to the bar.
      Ask FixBot
Unless the chosen battery is different, reassembly is in reverse order.
Author
with
Brandon
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 79
All Time: 1,719
