Logic Board Duplicate Guide
Views: 1.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
18
All Time:
1,315
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Archived Guide This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
Follow this guide if your phone's logic board needs to be replaced.
Tools
    1. Logic Board Duplicate Guide, Logic Board: step 1, image 1 of 2 Logic Board Duplicate Guide, Logic Board: step 1, image 2 of 2
      • Face the phone's back cover towards you. Press the oval-shaped button located at the bottom of the cover.
      • While holding this button, slide the back cover off. This should expose the battery.
      Ask FixBot
    2. Logic Board Duplicate Guide: step 2, image 1 of 1
      • Pull the battery out of the phone and set it aside.
      Ask FixBot
    3. Logic Board Duplicate Guide: step 3, image 1 of 2 Logic Board Duplicate Guide: step 3, image 2 of 2
      • Identify the four screw locations.
      • Use a torx screwdriver to unscrew the four screws located on the back of the phone. In order to unscrew a screw, insert your screwdriver into a screw and rotate the screwdriver counterclockwise.
      • Once each of the screws are removed, set them aside.
      Ask FixBot
    4. Logic Board Duplicate Guide: step 4, image 1 of 1
      • Unscrew the antenna by twisting it counterclockwise.
      Ask FixBot
    5. Logic Board Duplicate Guide: step 5, image 1 of 1
      • Remove the back cover by identifying a line of separation between the front and back of the phone.
      • Pull on both sides of the phone, front and back, in opposite directions. This will remove the back cover and reveal the logic board.
      Ask FixBot
    6. Logic Board Duplicate Guide: step 6, image 1 of 2 Logic Board Duplicate Guide: step 6, image 2 of 2
      • Identify the orange strip attached to the upper right hand corner of the logic board.
      • Detach this strip by pulling it off of the logic board but not off the phone itself. This will then enable you to pull your logic board off.
      • Pay attention to the orientation of the logic board as you will use this same orientation when you insert the new logic board.
      Ask FixBot
    7. Logic Board Duplicate Guide: step 7, image 1 of 1
      • Attach your new logic board to the orange strip by pushing it on to the new logic board. Set the logic board back in the phone casing.
      Ask FixBot
iDeleted
2,101 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 1,315
