Up to 20% off select tools
Logic Board Disconnection
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
32
All Time:
676
Comments: 38
38 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
  • Spudger
    4.9
  • T3 Torx Screwdriver
    4.8
  • Tweezers
Introduction
Go to step 1 ↓
Prerequisite-only guide to disconnect the logic board in a 2019 MacBook Air.
    1. Logic Board Disconnection, Disconnect the logic board: step 1, image 1 of 2 Logic Board Disconnection, Disconnect the logic board: step 1, image 2 of 2
      • Use a T3 Torx driver to remove the two 1.4 mm screws securing the trackpad connector bracket.
      • Depending on the condition of your bits, a T4 Torx driver may fit better.
      • Remove the trackpad connector bracket.
      Ask FixBot
    2. Logic Board Disconnection: step 2, image 1 of 2 Logic Board Disconnection: step 2, image 2 of 2
      • Use the flat end of a spudger to pry the trackpad cable connector up and out of its socket.
      Ask FixBot
    3. Logic Board Disconnection: step 3, image 1 of 3 Logic Board Disconnection: step 3, image 2 of 3 Logic Board Disconnection: step 3, image 3 of 3
      • If the left speaker is already disconnected, skip this step.
      • Slide the tip of a spudger underneath the left speaker cable and pry straight up to disconnect the speaker.
      • With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
      Ask FixBot
    4. Logic Board Disconnection: step 4, image 1 of 2 Logic Board Disconnection: step 4, image 2 of 2
      • If you're replacing the battery, see the comments for an alternative procedure that doesn't require removing the logic board.
      • Use a T3 Torx driver to remove the two 1.3 mm screws securing the USB-C port connector bracket.
      • Remove the USB-C connector bracket.
      Ask FixBot
    5. Logic Board Disconnection: step 5, image 1 of 2 Logic Board Disconnection: step 5, image 2 of 2
      • Use the flat end of a spudger to pry the USB-C cable connector up and out of its socket on the logic board.
      Ask FixBot
    6. Logic Board Disconnection: step 6, image 1 of 3 Logic Board Disconnection: step 6, image 2 of 3 Logic Board Disconnection: step 6, image 3 of 3
      • Use a spudger to lift up the small locking flap on the sound board cable's ZIF connector.
      • Slide the sound board cable out of the ZIF connector.
      Ask FixBot
    7. Logic Board Disconnection: step 7, image 1 of 1
      • Peel back the black tape covering the fan cable connector.
      Ask FixBot
    8. Logic Board Disconnection: step 8, image 1 of 3 Logic Board Disconnection: step 8, image 2 of 3 Logic Board Disconnection: step 8, image 3 of 3
      • Use the tip of a spudger to lift up the locking flap on the fan cable's ZIF connector.
      • Slide the fan cable out of the ZIF connector.
      Ask FixBot
    9. Logic Board Disconnection: step 9, image 1 of 2 Logic Board Disconnection: step 9, image 2 of 2
      • Use a T3 Torx driver to remove the two 1.4 mm screws securing the antenna cable bracket.
      • Remove the antenna cable bracket.
      Ask FixBot
    10. Logic Board Disconnection: step 10, image 1 of 3 Logic Board Disconnection: step 10, image 2 of 3 Logic Board Disconnection: step 10, image 3 of 3
      • Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable.
      • Repeat for the other antenna cable.
      Ask FixBot
    11. Logic Board Disconnection: step 11, image 1 of 2 Logic Board Disconnection: step 11, image 2 of 2
      • Use a T3 Torx driver to remove the two 1.5 mm screws securing the display cable connector bracket.
      • Remove the display cable connector bracket.
      Ask FixBot
    12. Logic Board Disconnection: step 12, image 1 of 2 Logic Board Disconnection: step 12, image 2 of 2
      • Use the flat end of a spudger to pry up the display cable connector.
      Ask FixBot
Author
with
Adam O'Camb
226,648 Reputation
415 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 676
