Introduction
Use this guide to replace the throttle lever and cable in a Little Beaver Augers MDL5HD 2017.
The auger bit is removed in this guide. While not necessary, removing it will make the repair easier.
Use a Phillips #2 screwdriver to loosen the screw securing the throttle cable clamp.
Use needle nose pliers to bend the flared end of the rivet inward to straighten it.
