Introduction
If the disc tray has fallen out of alignment or has broken, you will need to replace it.
Insert an open paper clip into the small hole on the left side of the faceplate.
After the tray opens, extend it fully.
Use an opening device to push in the black tabs on the left, right and bottom of the outer chassis to unhook the faceplate.
Extend the tray fully.
Push the tab on the right side to the left.
Push the tab on the left side to the left.
Remove the tray carefully.
Guide the replacement tray under the beige tabs.
Make sure the grey piece is slid to the right, so the grey nob is under the right-hand groove of the tray.
Check to see that the tray extends and closes smoothly.
