Lip Balm Replacement
View statistics:
Past 24 Hours:
8
Past 7 Days:
52
Past 30 Days:
144
All Time:
627
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Lip balms often break or become deformed due to temperature conditions, improper storage or handling accidents. This guide will help you to remold your lip balm to working condition.
This guide is to fix broken or damaged lip balm in chapstick tubes. This guide applies to any brand of tube chapstick with a twisting mechanism only, other designs may need specialized guides. This guide will not aid in repairing the tube itself or cleaning dirty lip balm, so if your chapstick is contaminated with debris, or missing more than half of the balm, it is best to discard and replace it.
Tools
    1. Lip Balm Replacement, Lip Balm: step 1, image 1 of 3 Lip Balm Replacement, Lip Balm: step 1, image 2 of 3 Lip Balm Replacement, Lip Balm: step 1, image 3 of 3
      • Uncap the lip balm and twist the tube clockwise to bring the lip balm up.
      Ask FixBot
    2. Lip Balm Replacement: step 2, image 1 of 2 Lip Balm Replacement: step 2, image 2 of 2
      • Scrape out the lip balm with the stirrer and place the pieces into a microwave safe bowl.
      Ask FixBot
    3. Lip Balm Replacement: step 3, image 1 of 2 Lip Balm Replacement: step 3, image 2 of 2
      • Twist the tube counterclockwise to retract and use a cotton swab to clean the container.
      Ask FixBot
    4. Lip Balm Replacement: step 4, image 1 of 3 Lip Balm Replacement: step 4, image 2 of 3 Lip Balm Replacement: step 4, image 3 of 3
      • Melt the lip balm with the heat gun, holding it 4-5 inches away from the bowl.
      • Stir occasionally to remove lumps.
      • You can optionally add scents, colors, or flavors during this step.
      • The bowl may be hot from the heat gun. Use a towel to hold the bowl in place while stirring.
      Ask FixBot
    5. Lip Balm Replacement: step 5, image 1 of 3 Lip Balm Replacement: step 5, image 2 of 3 Lip Balm Replacement: step 5, image 3 of 3
      • Pour in the melted lip balm through the funnel.
      • Make sure the lip balm container is upright.
      • The bowl may still be hot. Use a towel when handling.
      Ask FixBot
    6. Lip Balm Replacement: step 6, image 1 of 1
      • Allow the lip balm to cool in an upright position.
      • Let it sit for around 10-15 minutes.
      Ask FixBot
    7. Lip Balm Replacement: step 7, image 1 of 2 Lip Balm Replacement: step 7, image 2 of 2
      • Once cool, twist clockwise to bring the lip balm up. Enjoy your new lip balm!
      Ask FixBot
Follow the instructions in this guide to fix any broken lip balm or lipstick. In less than 30 minutes, your lip product will be good as new!
Amika Rudrawal
145 Reputation
1 Guide authored
UC Davis, Team 3-30, Serviss Fall 2025 Member of UC Davis, Team 3-30, Serviss Fall 2025
UCD-SERVISS-F25S3G30
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 52
Past 30 Days: 144
All Time: 627
