Open the access panel to the lint filter and remove it by carefully pulling it to the side.
Check that the spare part sieve fits. Position the drill on one of the crescent-shaped recesses of the lint filter cover and place the hole close to the hole. Once all possible holes have been drilled all around, you can use the drill to cut through the remaining webs between the holes. Use the side of the drill as a cutter.
Screw in replacement lint filter
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
