Installing Linksys WRT54GS v2 Rear Case
  1. Installing Linksys WRT54GS v2 Rear Case, Front Case: step 1, image 1 of 1
    • Turn the router over so that all four of its feet are facing upwards.
  2. Installing Linksys WRT54GS v2 Rear Case: step 2, image 1 of 1
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Installing Linksys WRT54GS v2 Rear Case: step 3, image 1 of 1
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  4. Installing Linksys WRT54GS v2 Rear Case: step 4, image 1 of 1
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
  5. Installing Linksys WRT54GS v2 Rear Case, Motherboard: step 5, image 1 of 1
    • Slide the board unit out and up.
  6. Installing Linksys WRT54GS v2 Rear Case: step 6, image 1 of 1
    • Flip the circuit board over and use a Phillips #2 Screwdriver to remove the 6.9mm screw holding the board to the back case.
    • Slide the back cover out and away from the circuit board.
  7. Installing Linksys WRT54GS v2 Rear Case, Rear Case: step 7, image 1 of 1
    • Removing the router's rear case is the same as removing the motherboard, since the two parts are attached to each other.
    • To remove the rear case follow the instructions in Installing the Motherboard guide.
    • Once you complete this step, your router will be completely disassembled.
Allian Roman
276 Reputation
5 Guides authored
Cal Poly, Team 3-4, Regan Fall 2011 Member of Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Members
12 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,482
