Introduction
If, after reading through this guide, you are still in need of assistance, please refer back to the device page or the troubleshooting page.
To remove the black casing that surrounds the green motherboard, slide the top half of the casing backwards. It only moves a very short distance.
Pull the top piece upwards and away from the bottom to remove.
Locate the 2 M2.5x6mm screws that attach the motherboard to the back case.
Remove the two screws from the motherboard as indicated with the Phillips head screwdriver.
Once screws have been removed, slide the motherboard in the direction of its LED lights.
Lift motherboard up and away from the black lower casing.
Obtain a desoldering wick (Desoldering Braid). Plug in soldering iron and allow to heat. For soldering information, refer to the iFixit soldering guide (How To Solder and Desolder Connections).
Identify the functional component which will be removed.
Turn the board over so that the pins holding the component in are exposed.
Desolder each pin using the iFixit Soldering Guide (How To Solder and Desolder Connections). Gently remove functional component for replacement.
