Introduction
Sending and receiving wireless signals requires an antenna. If the antenna is faulty, the device will not work as intended. Replacing the antenna should resolve most connectivity issues.
Be sure the ethernet and power cables are disconnected from the device.
You should also unscrew the external plastic antennas. There is one antenna on each side of the device.
Tool used on this step:Tweezers$4.99
Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot. Once you are hooked behind the boot, pull outwards.
This will reveal two small Phillips-head screws. Remove them.
Using a Phillips screwdriver remove the the three screws that fasten the main circuit board to the chassis.
