Linear Rail V2/V3 Endstop Install
    1. Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: step 1, image 1 of 3 Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: step 1, image 2 of 3 Linear Rail V2/V3 Endstop Install, Linear Rail V2/V3 Endstop Install: step 1, image 3 of 3
      • M3 Sliding T-Nut
      • Slide in the M3 T-Nut toward the middle of the printer
      • M3X12 BHCS & M3 FLAT WASHERS
      • M3x10 FHCS
      • Adjustable Endstop Mount A
      • Adjustable Endstop Mount B
      • Tighten the M3 screw into the T-Nut
      Ask FixBot
    2. Linear Rail V2/V3 Endstop Install, Endstop install: step 2, image 1 of 2 Linear Rail V2/V3 Endstop Install, Endstop install: step 2, image 2 of 2
      • Adjust endstop mount until it is square with the Linear rail
      • Remove stock endstop board form Creality mount and Reuse the stock screws to mount the endstop as shown
      Ask FixBot
    3. Linear Rail V2/V3 Endstop Install, Setting endstop position: step 3, image 1 of 2 Linear Rail V2/V3 Endstop Install, Setting endstop position: step 3, image 2 of 2
      • Use M3x12 BHCS to adjust the endstop position, so the nozzle tip is even with the front edge of the bed when the end stop is triggered
      • Check the clearance between the motor and the linear adaptor. When the bed is all the way back against the endstop. There should be a 1-2 mm gap when the endstop is triggered.
      Ask FixBot
AJ Pereira
2,744 Reputation
16 Guides authored
Tiny Machines 3D Member of Tiny Machines 3D
Community
5 Members
372 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 106
All Time: 2,550
