Up to 20% off select tools
Lighting - Advanced
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
2
All Time:
73
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Lighting - Advanced
Tools
    1. Lighting - Advanced, Lighting: step 1, image 1 of 3 Lighting - Advanced, Lighting: step 1, image 2 of 3 Lighting - Advanced, Lighting: step 1, image 3 of 3
      • IF YOU HAVE OVEREXPOSURE ISSUES, reduce the exposure comp by -0.5, up to -1.0; additional corrections should be made in post. Look for 5000-5500k LED panels unless you set a custom WB or know to correct the blue tint 6000-6500k panels produce.
      • If you are on a tight budget, look for lights with a tripod mount. Many low-cost video lights favor a tripod mount over light stands.
      • Budget lights
      • If you are on a limited budget, look for lights with a tripod mount like the SmallRig lights, as well as others like the Meike Y600/700 lights. Most budget lights use a tripod mount so a $10-15 tripod can be used rather than a light stand.
      • Professional lights
      • Some lights like Genarary LED panels meant for professional use often favor/require light stands are either not designed for tripod mounts, or it is an afterthought. While many "work" on tripods, it is often an afterthought.
      • If you get a good deal on these lights from a surplus sale (or have the budget), many of these work significantly better than "budget" lights. However, this comes at the price: you may pay significantly more, or they require a dedicated light stand if they do not mount to a standard tripod.
      Ask FixBot
    2. Lighting - Advanced, Light placement: step 2, image 1 of 3 Lighting - Advanced, Light placement: step 2, image 2 of 3 Lighting - Advanced, Light placement: step 2, image 3 of 3
      • If you use a flexible tripod as shown in the 3rd photo for the "fixed" light, the tripod may suddenly fail. The best way to avoid this is to use a proper articularing arm or desk clamp.
      • Your lighting setup will likely vary based on how you setup your photo background. In general, one light should be "fixed" with the other light being flexible.
      • Tripod mount
      • For best results, use a specialized clamp for side lights, or a tilting tripod.
      • Place your light(s) on an angle that will minimize reflections. NOTE: While the tripod light will need frequent adjustment, the side light should be mounted where adjustment needs are minimized.
      • Light stand mounted lights
      • These lights require a dedicated light stand unless a tripod mount is available. Light adjustment is generally done on the light frame.
      • Install the light on the stand from a flat angle; these are adjusted on the light frame. Once mounted, make any final adjustments you want and "lock" the panel in place.
      Ask FixBot
Nick
107,096 Reputation
73 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 73
