Lighting: Replacing Light Emitting Diode
  1. Lighting: Replacing Light Emitting Diode, Light Emitting Diode: step 1, image 1 of 1
    • Using a plastic opening tool, remove the base of the Light Angel.
    • Insert the plastic opening tool between the base and the LED housing and pull outwards on the handle.
  2. Lighting: Replacing Light Emitting Diode: step 2, image 1 of 1
    • Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
    • To remove the screw, turn counterclockwise.
    • Remember to put all the screws you take out somewhere safe so you can find them when it's time to reassemble the light.
  3. Lighting: Replacing Light Emitting Diode: step 3, image 1 of 1
    • Remove and set aside the (4) AA batteries in the battery housing.
  4. Lighting: Replacing Light Emitting Diode: step 4, image 1 of 1
    • Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
    • To remove the screws, turn counterclockwise.
  5. Lighting: Replacing Light Emitting Diode: step 5, image 1 of 1
    • Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
  6. Lighting: Replacing Light Emitting Diode: step 6, image 1 of 1
    • Locate the faulty light emitting diode on the back of the circuit board.
    • Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
    • Do not allow the soldering iron to come in contact with other components on the circuit board.
    • For detailed instructions on how to solder go to How To Solder and Desolder Connections
  7. Lighting: Replacing Light Emitting Diode: step 7, image 1 of 1
    • Insert the new light emitting diode through the two holes left from removing the old one.
    • Note: the picture is not of the Light Angel circuit board. It is a general example of inserting a light emitting diode on a circuit board. Photo Credit: How To Solder and Desolder Connections
  8. Lighting: Replacing Light Emitting Diode: step 8, image 1 of 1
    • Using solder and a soldering iron, solder the new LED to the circuit board.
    • Keep your solder joints separate to avoid short circuiting the circuit board.
2 other people completed this guide.
Matthew Corigliano
155 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 78
All Time: 4,673
