LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming
  1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: step 1, image 1 of 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: step 1, image 2 of 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: step 1, image 3 of 3
    • Use a spudger to gently pry open the remote case to access the battery compartment.
  2. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 2, image 1 of 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 2, image 2 of 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 2, image 3 of 3
    • Carefully remove the old battery using a spudger.
  3. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 3, image 1 of 2 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 3, image 2 of 2
    • Place the new battery into the compartment securely, noting the orientation of its positive and negative sides.
  4. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 4, image 1 of 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 4, image 2 of 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 4, image 3 of 3
    • Turn the remote upside down and push the cover gently until you hear a click, ensuring it is securely closed.
    • Align the cover to the remote buttons.
  5. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 5, image 1 of 2 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 5, image 2 of 2
    • Locate the garage door system on top of the garage and open it.
  6. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 6, image 1 of 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 6, image 2 of 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 6, image 3 of 3
    • Locate the learn button.
    • Press and release the receiver learn button.
    • Within 30 seconds, press and hold remote button.
    • When the opener light flashes, release the remote button which means the programming was successful.
  7. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 7, image 1 of 1
    • Press the remote button to ensure it opens and closes the garage door as expected.
    • If the remote does not work, repeat Step 6.
  8. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: step 8, image 1 of 1
    • In case the remote fails and the garage door is closed, use the side-mounted wall remote for emergency access.
    • Press the green light.
Finish Line
Luay Ghabayin
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 146
All Time: 1,446
