LexiBook Tablet One Battery Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
84
All Time:
2,273
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show the user how to remove the battery and replace it. Will require a plastic spudger, a careful hand, and some patience.
Tools
    1. LexiBook Tablet One Battery Replacement, Battery: step 1, image 1 of 3 LexiBook Tablet One Battery Replacement, Battery: step 1, image 2 of 3 LexiBook Tablet One Battery Replacement, Battery: step 1, image 3 of 3
      • First the case must be opened. Insert the blue plastic opening tool where the two casings meet. Pry up until you hear a clip pop and then carefully move around the device. Do this until the front and back casing are completely separate from one another.
      • You will again need to be careful opening the device in order to avoid damaging the speaker, or worse, the motherboard.
      • The clips holding the case together are roughly 1.5 in. apart.
      Ask FixBot
    2. LexiBook Tablet One Battery Replacement: step 2, image 1 of 2 LexiBook Tablet One Battery Replacement: step 2, image 2 of 2
      • Carefully remove the speaker by inserting the spudger between the case and the speaker. Pry upwards until the speaker comes out. Set the speaker to the side.
      • Be careful with the speaker wires. The wires can easily detach from both the speaker and the board.
      Ask FixBot
    3. LexiBook Tablet One Battery Replacement: step 3, image 1 of 1
      • Use the spudger to repeatedly gouge between the battery and LCD. Work around the battery until it breaks free.
      • It may feel as though you are pushing extremely hard. This is normal as the adhesive is quite strong. As long as you don't tip the tool you use and puncture the battery / LCD it will be fine.
      Ask FixBot
    4. LexiBook Tablet One Battery Replacement: step 4, image 1 of 2 LexiBook Tablet One Battery Replacement: step 4, image 2 of 2
      • The tape around the battery's circuit board is extremely thorough. There are 2 pieces of tape, on folded over the side and another wrapped around the circuit board. Simply peel both off.
      Ask FixBot
    5. LexiBook Tablet One Battery Replacement: step 5, image 1 of 2 LexiBook Tablet One Battery Replacement: step 5, image 2 of 2
      • Now that the battery is pry'd free and the tape is removed, the wires should be able to move freely. Give yourself as much room as you need, and solder off the connections on the motherboard.
      • How to Solder is iFixit's official guide to use a soldering gun.
      Ask FixBot
Jordan
650 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 84
All Time: 2,273
