Levoit Core Mini Air Purifier Filter Replacement
  1. Levoit Core Mini Air Purifier Filter Replacement, Filter: step 1, image 1 of 1
    • Press the power button on the top of the device to turn off the air purifier.
    Ask FixBot
  2. Levoit Core Mini Air Purifier Filter Replacement: step 2, image 1 of 2 Levoit Core Mini Air Purifier Filter Replacement: step 2, image 2 of 2
    • Unplug the air purifier from the power outlet.
    Ask FixBot
  3. Levoit Core Mini Air Purifier Filter Replacement: step 3, image 1 of 3 Levoit Core Mini Air Purifier Filter Replacement: step 3, image 2 of 3 Levoit Core Mini Air Purifier Filter Replacement: step 3, image 3 of 3
    • Flip the air purifier upside down so you can remove the bottom portion.
    Ask FixBot
  4. Levoit Core Mini Air Purifier Filter Replacement: step 4, image 1 of 2 Levoit Core Mini Air Purifier Filter Replacement: step 4, image 2 of 2
    • Turn the bottom of the device counter-clockwise towards the arrow pointed to "OPEN".
    Ask FixBot
  5. Levoit Core Mini Air Purifier Filter Replacement: step 5, image 1 of 2 Levoit Core Mini Air Purifier Filter Replacement: step 5, image 2 of 2
    • Once rotated, pull off the bottom case
    • You don't need to use much force. The bottom should lift off easily.
    Ask FixBot
  6. Levoit Core Mini Air Purifier Filter Replacement: step 6, image 1 of 3 Levoit Core Mini Air Purifier Filter Replacement: step 6, image 2 of 3 Levoit Core Mini Air Purifier Filter Replacement: step 6, image 3 of 3
    • Remove the old filter from the air purifier.
    • Check to see how the filter is positioned, so you know how the place the new one.
    Ask FixBot
  7. Levoit Core Mini Air Purifier Filter Replacement: step 7, image 1 of 2 Levoit Core Mini Air Purifier Filter Replacement: step 7, image 2 of 2
    • Place the new filter on the air purifier.
    Ask FixBot
  8. Levoit Core Mini Air Purifier Filter Replacement: step 8, image 1 of 2 Levoit Core Mini Air Purifier Filter Replacement: step 8, image 2 of 2
    • Replace the bottom case and turn it clockwise toward the arrow marked “Close” to secure it.
    Ask FixBot
  9. Levoit Core Mini Air Purifier Filter Replacement: step 9, image 1 of 2 Levoit Core Mini Air Purifier Filter Replacement: step 9, image 2 of 2
    • Flip it over so the top is facing up.
    • Plug it into the electrical outlet.
    Ask FixBot
  10. Levoit Core Mini Air Purifier Filter Replacement: step 10, image 1 of 1
    • Power on the air purifier and let it filter your room.
    Ask FixBot
AshayRalli
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 112
All Time: 690
