Introduction
This guide will show you how to remove the SSD of the Lenovo Yoga-900-13ISK2. As an extra precaution, the battery should be removed first before proceeding with the rest of the device.
  1. Flip the laptop so that the back panel is facing up. Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
    • Flip the laptop so that the back panel is facing up.
    • Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
  2. Gently lift the back cover off of the laptop.
    • Gently lift the back cover off of the laptop.
  3. Push the black battery cable towards the battery to disconnect it. Push the black battery cable towards the battery to disconnect it.
    • Push the black battery cable towards the battery to disconnect it.
  4. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  5. Remove the six #0 3.8mm Phillips screws from the battery. Remove the six #0 3.8mm Phillips screws from the battery.
    • Remove the six #0 3.8mm Phillips screws from the battery.
  6. Gently lift the battery out of the laptop chassis.
    • Gently lift the battery out of the laptop chassis.
  7. Remove the one #0 2.9mm Phillips screw from the SSD. Remove the one #0 2.9mm Phillips screw from the SSD.
    • Remove the one #0 2.9mm Phillips screw from the SSD.
  8. Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
    • Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
2 other people completed this guide.
Nathan Lui
761 Reputation
5 Guides authored
Cal Poly, Team S13-G6, Forte Spring 2017 Member of Cal Poly, Team S13-G6, Forte Spring 2017
CPSU-FORTE-S17S13G6
4 Members
6 Guides authored
2 Comments
For my Yoga 900 I needed a T5 Torx screw driver. Otherwise spot on.
Dan Benze - Reply
thanks for the info, what about the data from the original drive??
Jos Chan - Reply
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 124
All Time: 3,350
