Lenovo Yoga 720-15IKB Bottom Cover Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo Yoga 720-15IKB Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
    • Start by flipping the device over so that you see the screws.
    • Remove the 7 T5 short screws.
    • Remove the 3 long T5 screws.
  2. Lenovo Yoga 720-15IKB Bottom Cover Replacement: step 2, image 1 of 2 Lenovo Yoga 720-15IKB Bottom Cover Replacement: step 2, image 2 of 2
    • Starting at the left USB port use you opening tool to gently pry up the bottom case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop's edge as shown by the arrows.
    • Do NOT pry along the top side, or you will damage the casing. Stay with the arrows.
  3. Lenovo Yoga 720-15IKB Bottom Cover Replacement: step 3, image 1 of 1
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the bottom case.
dkay
226 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 96
