Introduction
The Computer cant be started by pushino go the power switch
Tool used on this step:Pro Tech Toolkit$74.95
Most of the necessary tools are part of the toolkit IFIXIT Pro Tech Toolkit
additionally is needed
soldering tools and materials (soldering pasta, soldering iron, soldering flux etc)
magnifying glass if necessary
The disassembling of the back cover is exactly the same like Lenovo Yoga 710-15IKB Back Cover Replacement
But here is the back cover inner site to see the snap fits
Remove the screws from HDD
Disconnect the flat cable from Motherboard
Disconnect the battery
Remove the screws
Remove the battery
Disconnect all the flat from motherboard in the same way as the HDD flat cable has been disconnected
Fan cable need to be disconnected too
Remove the screws of motherboard
Lift slightly the motherboard and remove it from pc
Turn the motherboard upside down
on the bottom side (which is now on the top) is the placed the power switch
place and solder the power switch on the motherboard
residues of solder should be removed by desoldering stranded wire
residues of flux should be removed too
During reassembling of motherboard in housing is necessary to pay attention to the power switch. The outside button must be precisely placed on the power switch
Follow the steps backward to reassemby the gadget again.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
