Introduction
This guide will show you how to remove the motherboard from the Lenovo Yoga 3 Pro. As an extra precaution, the battery should be removed first before proceeding with the rest of the device.
Flip the laptop so that the back panel is facing up.
Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
Using the plastic opening tool, gently pry the grey wire off the wifi card.
Pry the black wire off the wifi card.
Remove the one #0 2.9mm Phillips screw from the SSD.
5 other people completed this guide.
2 Comments
Hi. Do you have any idea where I could by a replacement motherboard and how much that would cost? Please answer to martin.loffler@gmail.com. Thank you so much. Best, Martin
