Lenovo Yoga 3 11 Lower Case Replacement
  1. Lenovo Yoga 3 11 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
2 other people completed this guide.
Geoff Wacker
90,010 Reputation
89 Guides authored
One Comment
Once you remove the T5 screws take notice of the two places where the lower cases design accounts for the LCD hinges. The lower case wraps over the edge and extends the entire length of the machine on the LCD edge to meet the black plastic of the upper case. You may want to use a thin edged sponger at points on either side of each hinge to dislodge the lower case. I found it best to begin removal of the lower case from the LCD edge. Once that edge is released the rest of the lower case will be much easier to release and remove. Subsequently when installing the new case begin by placing the LCD edge first. Go in at an angle necessary to set the edge that wraps over. This guide and this comment applies to the 3 11 and the 3 14.
John Wolmer - Reply
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 25
All Time: 1,656
