Introduction
This guide will walk you through with replacing the fan of your device. You're going to need to sit down and unscrew a lot of screws to access the fan of your device.
Flip the device so the back is facing you.
Using the Phillips #0 screwdriver, unscrew the fourteen screws from the device.
Use the blue Opening Tool to pry-open the back cover.
Slide it around the perimeter of the PC freeing the back cover.
Remove the back cover from the device.
Using the Phillips #0 screwdriver, remove the three screws connecting the fan to the device.
Using a pair of blunt tweezers, disconnect the fan from the motherboard.
Remove the fan from the device.
