Lenovo Vibe Z2 Pro Battery Replacement
  1. Lenovo Vibe Z2 Pro Battery Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: step 1, image 1 of 2 Lenovo Vibe Z2 Pro Battery Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: step 1, image 2 of 2
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Battery Replacement: step 2, image 1 of 1
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Battery Replacement: step 3, image 1 of 2 Lenovo Vibe Z2 Pro Battery Replacement: step 3, image 2 of 2
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Battery Replacement: step 4, image 1 of 2 Lenovo Vibe Z2 Pro Battery Replacement: step 4, image 2 of 2
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Battery Replacement: step 5, image 1 of 1
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Battery Replacement, Battery: step 6, image 1 of 2 Lenovo Vibe Z2 Pro Battery Replacement, Battery: step 6, image 2 of 2
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Battery Replacement: step 7, image 1 of 2 Lenovo Vibe Z2 Pro Battery Replacement: step 7, image 2 of 2
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Battery Replacement: step 8, image 1 of 1
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Battery Replacement: step 9, image 1 of 3 Lenovo Vibe Z2 Pro Battery Replacement: step 9, image 2 of 3 Lenovo Vibe Z2 Pro Battery Replacement: step 9, image 3 of 3
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
4 other people completed this guide.
Bryan Sepulveda
547 Reputation
3 Guides authored
USF Tampa, Team 18-3, Blackwell Fall 2016 Member of USF Tampa, Team 18-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G3
4 Members
12 Guides authored
2 Comments
Where to buy such battery?
Damir Dominko - Reply
wala pa po ba dito s pinas ng bl230?
eduardo santos - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 3,354
