Introduction
This will serve as a guide to replace the RAM (Random Access Memory) in a Lenovo V14 ADA MODEL NUMBER: 82C6S03E00, either for repair or upgrade purposes. RAM acts as the short term storage in a system, only containing data for applications that are currently in use. It enables the system to run much faster that it would if it always had to read application data from a drive.
When upgrading or replacing RAM in a system, it is important to know the generation of RAM your system will accept. In this system, the RAM used is PC4, or DDR4. Using a different generation of RAM will make the laptop not function. When purchasing a new RAM module for this replacement, ensure that it is a DDR4 SODIMM RAM module; a larger DIMM module meant for a PC will not work.
Faulty RAM can cause
- Failure to boot.
- Frequent Blue Screens, with these codes given as the reason.
- MEMORY_MANAGEMENT (0x0000001A)
- PAGE_FAULT_IN_NONPAGED_AREA (0x00000050)
- IRQL_NOT_LESS_OR_EQUAL (0x0000000A)
- SYSTEM_SERVICE_EXCEPTION (0x0000003B)
- Random Crashes and Freezes.
- Stuttering in RAM heavy applications, like gaming.
- RAM missing from task manager.
This link leads to troubleshooting tips for your system’s RAM.
Turn off the laptop.
Disconnect the charging cable from the laptop.
Flip the laptop upside down.
Push the retaining arms away from the RAM module.
Remove the module after it pops up at an angle.
