Lenovo Thinkpad Yoga 370 M2 SSD Replacement
  1. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the specific model and locate the screws to loose: step 1, image 1 of 2 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the specific model and locate the screws to loose: step 1, image 2 of 2
    • Before remove the back-case of the laptop we have to remove the Pen Pro and the SD card if it is in your model (two boxes in orange on one of the photos).
    • Circles show the screws to loose. The yellow square indicates where the information about Model is found (20JJ in this case).
  2. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Loose the screws and take away the back case: step 2, image 1 of 3 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Loose the screws and take away the back case: step 2, image 2 of 3 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Loose the screws and take away the back case: step 2, image 3 of 3
    • Note that after loose the screws we have to remove the case from the bottom part.
    • The all the screws remain attached to the back-cover as shown in the photos.
    • Note that the top part of the laptop back cover has several hooks done with plastic (see the photos with blue squares)
  3. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the M2.SSD and the screw that attach it to the main board: step 3, image 1 of 2 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Identify the M2.SSD and the screw that attach it to the main board: step 3, image 2 of 2
    • Laptop after remove the back-cover. The area in red has the M2.SSD.
    • The blue arrow shows where is the adhesive part of the M2.SSD that we have to carefully lift off but keeping attached the other part of the cover.
    • The green arrow shows the screw that we would have to remove to take away the M2.SSD.
  4. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Remove the screw and insert the M2.SSD.: step 4, image 1 of 3 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Remove the screw and insert the M2.SSD.: step 4, image 2 of 3 Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Remove the screw and insert the M2.SSD.: step 4, image 3 of 3
    • First step is remove the screw (this one has to be full removed).
    • Then we can introduce the new M2.SSD, with a little bit of pressure.
    • Finally we can fix it with the previously removed screw. Everything should fit well without forcing any component.
  5. Lenovo Thinkpad Yoga 370  M2 SSD Replacement, Attach again the back case.: step 5, image 1 of 1
    • To close the back case of the laptop we have to remember the position of the small hooks. Then apply some pressure and screw first the screws on top
    • After screw again all the 9 screws, we can attach again the Pen Pro and the SD card.
    • Its done.
2 other people completed this guide.
Attached Documents
Ramiro
178 Reputation
1 Guide authored
1 Guide Comment
excellent and easy to follow instruction. I used your set and sent it to a senior that needed to fix their laptops. No prior experience. It worked like a charm.
Austin - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 40
All Time: 7,114
