Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement
  1. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Battery: step 1, image 1 of 1
    • Device needs to be powered off and unplugged.
    • Remove the stylus from the device and set it aside.
  2. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 2, image 1 of 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 2, image 2 of 2
    • Using the Phillips #00 screwdriver unscrew the eight circled 4mm screws until you hear a click.
    • The screws will remain attached to the back cover.
  3. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 3, image 1 of 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 3, image 2 of 2
    • Note that while the screws are undone, the bottom cover is still attached by several plastic clips around the edges.
    • Using the plastic opening tool, work around the edges of the bottom cover to undo the plastic clips.
  4. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 4, image 1 of 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 4, image 2 of 2
    • Gently remove the cover by placing your fingers around the edges.
  5. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 5, image 1 of 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 5, image 2 of 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 5, image 3 of 3
    • With your fingers, fold back the plastic cover highlighted.
    • Using two fingers, gently remove the battery connectors.
  6. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 6, image 1 of 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 6, image 2 of 3 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 6, image 3 of 3
    • Using the Phillips #00 screwdriver, remove the two 4mm screws.
    • Remove the battery.
    • Make sure to only replace with a battery that matches your computer, any other battery could ignite or explode.
  7. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement, Fingerprint Reader: step 7, image 1 of 1
    • Identify the fingerprint reader on the left side of the laptop.
  8. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • To disconnect the fingerprint reader from the motherboard, unlock the ZIF connector and pull it out using tweezers.
  9. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 9, image 1 of 2 Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 9, image 2 of 2
    • Remove the one 4 mm screw from the metal covering with the Phillips #00 screwdriver.
    • Remove the metal cover.
  10. Lenovo ThinkPad Yoga 370 Fingerprint Reader Replacement: step 10, image 1 of 1
    • Using tweezers, remove the fingerprint reader from the inset.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 23
All Time: 721
