Lenovo ThinkPad X240 - Hard Disk Drive Replacement
  1. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement, Hard Disk Drive and Solid State Drive: step 1, image 1 of 1
    • Flip the laptop upside down as shown in the photo.
  2. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: step 2, image 1 of 2 Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: step 2, image 2 of 2
    • Remove the 8 0.2mm Phillips screws connecting the back cover to the laptop.
  3. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: step 3, image 1 of 1
    • Remove the back cover using the opening tools.
    • Gently use the plastic opening tools to prevent scratching your device.
  4. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: step 4, image 1 of 1
    • Remove the Hard Disk Drive card by screwing the 2 0.2mm Phillips screw
  5. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: step 5, image 1 of 1
    • Disconnect the SATA cable from the hard drive.
  6. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: step 6, image 1 of 1
    • Take off the connector by carefully popping its holders out of place
  7. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: step 7, image 1 of 1
    • Reconnect the cable to the new Hard Disk Drive
  8. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: step 8, image 1 of 1
    • place the connector in order to hold the cable
  9. Lenovo ThinkPad X240 -  Hard Disk Drive  Replacement: step 9, image 1 of 1
    • Place the new Hard Drive Disk
11 other people completed this guide.
6 Guide Comments
Hello, i think you forgot to disconnect internal battery first before you replace something
shofaribagus - Reply
That is true, that'd been a much safer way to do it.
Mahir Max -
Tip for the case screws, they are captive don’t worry about them
Baddo-M _ - Reply
Yes, good point - case screws are captive and easy to keep in place when lifting the cover. But overall this is a well written guide, so thanks for this.
Ricky Las Vegas - Reply
If you have an SD card in the SD card reader make sure to remove it before trying to remove the case cover, otherwise it will not come off, and you risk damaging your motherboard if you force it.
David Huggins-Daines - Reply
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 96
All Time: 16,647
