Lenovo ThinkPad X1 Extreme SSD Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
95
All Time:
3,330
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will lead you through the steps to replace the SSD card on the Lenovo ThinkPad X1 Extreme Generation 1. The SSD card, or solid-state drive, acts as extra storage for the device, however, oftentimes the SSD can wear out, or run slower with age.
The steps to replace the SSD card are simple, the hardest part being keeping track of all the screws while taking apart the device.
It is important to remember to turn off the device while replacing the SSD card.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: step 1, image 1 of 3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: step 1, image 2 of 3 Lenovo ThinkPad X1 Extreme SSD Replacement, Back Cover: step 1, image 3 of 3
      • Power off and unplug your device before you begin.
      • Orient the laptop so that it is bottom up, and the trackpad is closest to you.
      • Unscrew the seven captive screws with a Phillips #00 screwdriver.
      • These screws will loosen, but stay attached to the cover. Do not attempt to completely remove them.
      • Slide a blue opening pick in the gap between the bottom panel and chassis, and pry off the one clip on each side.
      • Remove the back cover from the device.
      Ask FixBot
    1. Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: step 2, image 1 of 2 Lenovo ThinkPad X1 Extreme SSD Replacement, SSD: step 2, image 2 of 2
      • Using the Phillips #00 screwdriver, remove the single screw securing the SSD to the motherboard.
      Ask FixBot
    2. Lenovo ThinkPad X1 Extreme SSD Replacement: step 3, image 1 of 2 Lenovo ThinkPad X1 Extreme SSD Replacement: step 3, image 2 of 2
      • Using the opening tool, pop out the SSD card and remove it from the device.
      Ask FixBot
1 Guide Comment
Anyhow this laptop support gen 4 nvme or higher?
jordan chong - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 95
All Time: 3,330
