Lenovo ThinkPad T530 Optical Drive Reader Replacement
  1. Lenovo ThinkPad T530 Optical Drive Reader Replacement, Place your laptop upside down: step 1, image 1 of 2 Lenovo ThinkPad T530 Optical Drive Reader Replacement, Place your laptop upside down: step 1, image 2 of 2
    • Ensure that the laptop is disconnected from the wall charger, and that the laptop is entirely powered off before following any of the steps below.
    • Flip your laptop upside down, so that the keyboard is facing down.
  2. Lenovo ThinkPad T530 Optical Drive Reader Replacement, Unlock Battery: step 2, image 1 of 2 Lenovo ThinkPad T530 Optical Drive Reader Replacement, Unlock Battery: step 2, image 2 of 2
    • Locate the latch located on the battery near the top of the laptop.
    • Using your finger, slide the latch to the right-most (Unlocked) position.
    • None of this should require an exhuberant amount of force.
  3. Lenovo ThinkPad T530 Optical Drive Reader Replacement, Remove the Battery: step 3, image 1 of 2 Lenovo ThinkPad T530 Optical Drive Reader Replacement, Remove the Battery: step 3, image 2 of 2
    • You can now pull the battery away from the laptop. When pulling the battery out, ensure to pull it out straight.
  4. Lenovo ThinkPad T530 Optical Drive Reader Replacement, Removing the Optical Drive: step 4, image 1 of 3 Lenovo ThinkPad T530 Optical Drive Reader Replacement, Removing the Optical Drive: step 4, image 2 of 3 Lenovo ThinkPad T530 Optical Drive Reader Replacement, Removing the Optical Drive: step 4, image 3 of 3
    • Locate the locking switch, highlighted in red. Move the switch up, to the unlocked position.
    • Locate the release switch, highlighted in orange. Move the switch to the left, to the release position.
  5. Lenovo ThinkPad T530 Optical Drive Reader Replacement, Removing the Optical Drive (Continued): step 5, image 1 of 2 Lenovo ThinkPad T530 Optical Drive Reader Replacement, Removing the Optical Drive (Continued): step 5, image 2 of 2
    • The Optical Drive should eject out of its slot, and you should be able to pull it out of the slot entirely.
Attached Documents
Albert Stoynov
1,400 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 18
All Time: 319
